nwestty80 Posted April 16, 2014 Report Share Posted April 16, 2014 Just got the lad a Beta 80 and set about changing the gear oil as it looked a bit dirty and I wanted a piece of mind.The guy I bought it off gave me some YAMALUBE OIL that he said he has used in the gearbox for last 2 years or so.I drained the oil and put in the 300 ml as per manual but upon starting and testing the bike in gear it appears that the bike is still driving a little even when the clutch is fully pulled in. Could it be thatr the oil is incorrect or is rthis a common fault and is there an adjustment that can be made or will other oil solve the problem? thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
jfc Posted April 16, 2014 Report Share Posted April 16, 2014 We used silkalean light gear oil never had a problem with clutch dragging. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted April 16, 2014 Report Share Posted April 16, 2014 i use atf in the daughters with no problems Quote Link to comment Share on other sites More sharing options...
nwestty80 Posted April 16, 2014 Author Report Share Posted April 16, 2014 Does it normally need bleeding after replacing gear oil? Quote Link to comment Share on other sites More sharing options...
nelly1 Posted April 17, 2014 Report Share Posted April 17, 2014 no very straight foreward Quote Link to comment Share on other sites More sharing options...
