motosolex Posted April 21, 2014 Report Share Posted April 21, 2014 Hello Trialists, I have access to a bearing supplier and would like to know the bearing number of the tapered Timken type steering bearings upper and lower to replace the OEM ball bearings. Thanks guys. Quote Link to comment Share on other sites More sharing options...
tony27 Posted April 21, 2014 Report Share Posted April 21, 2014 (edited) I use an All Balls/Moose racing kit #22-1008 which also contains seals, easily & cheaply sourced. Assuming you are in the UK the kit is about 20quid on ebay Bearing numbers are 25MI-G3YI for the top bearing, 30YMI-G8YI for the lower bearing, the G may be a 4 as it's not that distinct. For the longevity of your bearings you really need the seals but I can't help you with the numbers of them Edited April 21, 2014 by tony27 Quote Link to comment Share on other sites More sharing options...
