Tlr250 Cam Chain Sprocket
tlrider
Can anyone confirm if the U.S. market TLR200 Reflex Cam chain sprocket is the same as the TLR250 cam chain sprocket?
I have seen a sprocket listed on several of the UK parts suppliers sites listed as for the TLR200/250 but am not sure it is the same. Being in the States I would like to get it here to save on shipping for a low cost part if possible.
I have retarded the valve timing by rotating the sprocket one tooth to soften the snappiness and it is softer than I would like so I want to slot the bolt holes to be able to fine tune the timing without modifying my original part.
Cheers
@zerorev, I have not been able to find a parts list for the TLR250, they were never available in the States through Honda so it does not come up on the model list. There have been several threads here asking for access to a parts fiche but to the best of my knowledge one has never come available. The photo of the TLR200/250 sprocket from the UK sellers have the part covering the part number so I can't reference from there either.
@lineaway, Thanks for the link to the other thread. I need to slot the holes because I need a position that is a 1/2 tooth adjustment, can't really do that with the multi hole method.
