gassaman Posted May 9, 2014 Report Share Posted May 9, 2014 Help needed folks.... Can anyone tell me what the name of the breathable waterproof silicon / foam I need a to seal air box on my Evo as I been out today again and had to drain water from box twice, yes Iv been tootling about in the water / rocks but nothing deep but nevertheless water has yet again found it way in there!! Also where the most likely place I need to seal. The bike has had a new back mudguard fitted prior to me buying it so Im guessing I need to seal around that area too. {top of air box } Thank you in advance once again Quote Link to comment Share on other sites More sharing options...
rij Posted May 9, 2014 Report Share Posted May 9, 2014 Hello have a look at this http://www.ssdt.org/downloads/2012/Beta.pdf The stuff you need is pond pump filter Which help to stop water splashing straight in to the airbox £10 for three a3 size sheets Rich Quote Link to comment Share on other sites More sharing options...
motorcycleemptyness Posted May 9, 2014 Report Share Posted May 9, 2014 It's called Reticulated Foam . Get it from Tropical Fish Shops Quote Link to comment Share on other sites More sharing options...
westygas270 Posted May 10, 2014 Report Share Posted May 10, 2014 defo will reccomend the foam on my last beta i used it, you can also get a guard that goes under back mudguard and goes up back of exhaust these are also good idea, front mudguard flap may also stop a bit and a guard on the front pipe Quote Link to comment Share on other sites More sharing options...
