Fuel
scarboroughbeta
I don't think it's float height
Even if it was adjusted wrong it should not overflow
And remember, it probably didn't do it new and now it does so something has changed and floats don't adjust themselves
So its needle sealing, it's the only wear item in the area and it will change with time
Replace the needle (it has opened and closed hundreds of thousands of times, it's tired)
Use a Q tip and a little tooth paste and polish up the seat and of course set the float height correctly
