sms005 Posted May 14, 2014 Report Share Posted May 14, 2014 Hello all, I have an '07 2.9 that has some engine noise. Upon disassembly and inspection I learned the cylinder and piston are gouged up pretty good on the intake side. Eventually I'd like to send it out for re sleevin/plating, but in the meantime I have an opportunity to buy an '08 2.5 cylinder/piston/rings/clips for a decent price. This would minimize the downtime My question is would it be a direct swap out or is there more to it than I'm imagining. I assume I'll need a different base gasket. Will the exhaust match up to the 2.5? Will re jetting be required? Will the 2.9 ignition work for the 2.5? Anything else I'm missing? Thanks in advance... Quote Link to comment Share on other sites More sharing options...
copemech Posted May 15, 2014 Report Share Posted May 15, 2014 Everything should swap out directly with no changes, however the head is a different part number as I recall. Quote Link to comment Share on other sites More sharing options...
sms005 Posted May 15, 2014 Author Report Share Posted May 15, 2014 Everything should swap out directly with no changes, however the head is a different part number as I recall. Thanks! It actually comes with a head too so I'd be good to go! Quote Link to comment Share on other sites More sharing options...
copemech Posted May 15, 2014 Report Share Posted May 15, 2014 You may ck and verify with Splatshop Chris, but looks as though you may need to go with the narrow base gasket, and prolly use two of them for simplicity for the 250 cyl install. http://www.splatshop.co.uk/catalogsearch/result/?q=sherco+250+cylinder Quote Link to comment Share on other sites More sharing options...
