4Rt Gearbox Oil Continued.
shyted
9 hours ago, steve fracy said:
I would say it is very similar. I was a bit worried about what oil to use and could find the Elf anywhere. So I was quite relieved to know that using the Amsoil supershift has not changed anything in the way the clutch works at all
Just looking at the tech info for this and it is in fact a ATF oil but made for completion use -  makes sense why it works well and also probably has good additives for wear reduction.
  • 1 month later...
