jimmyl Posted June 8, 2017 Report Share Posted June 8, 2017 On 6/8/2017 at 2:42 AM, steve fracy said: I would say it is very similar. I was a bit worried about what oil to use and could find the Elf anywhere. So I was quite relieved to know that using the Amsoil supershift has not changed anything in the way the clutch works at all Expand Just looking at the tech info for this and it is in fact a ATF oil but made for completion use - makes sense why it works well and also probably has good additives for wear reduction. Quote Link to comment Share on other sites More sharing options...
tman427 Posted July 28, 2017 Report Share Posted July 28, 2017 In the US it is tough and expensive to get the ELF oils. I use BelRay Gearsaver 80 weight with the Honda dimpled clutch plates. Works excellent, super smooth clutch with this setup. Quote Link to comment Share on other sites More sharing options...
