bondy Posted May 18, 2014 Report Share Posted May 18, 2014 Hello anybody know if you canget the clips for the rear brake shoe pivet? Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted May 18, 2014 Report Share Posted May 18, 2014 Any good engineering outlet will have them. they are only circlips after all.Or try here. http://www.ebay.co.uk/itm/300pc-External-Circlips-retaining-ring-assortment-set-small-rap-around-cir-clip-/371024234085?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=ite Quote Link to comment Share on other sites More sharing options...
noel063 Posted May 18, 2014 Report Share Posted May 18, 2014 It's a circlip for gods sake not a special part. You can buy a tray of assorted sizes from either one of the well known DIY merchants. In case you need a clue one begins with T and the other with S Quote Link to comment Share on other sites More sharing options...
bondy Posted May 18, 2014 Author Report Share Posted May 18, 2014 Hello paul cheers for that.noel no need to get you knickers in a twist.i only ask a Question. 1 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 18, 2014 Report Share Posted May 18, 2014 (edited) Circlips for gads sake? I never new these were produced for his use, but as everyone should know God rides a Harley so presumably he will have had use for circlips at some time. http://simplybearings.co.uk/shop/index.html Edited May 18, 2014 by dadof2 Quote Link to comment Share on other sites More sharing options...
bondy Posted May 24, 2014 Author Report Share Posted May 24, 2014 Ok I ment to ask the size off the cir clip? Quote Link to comment Share on other sites More sharing options...
guys Posted May 24, 2014 Report Share Posted May 24, 2014 Just measure the diameter of the pivot, not in the groove where the circlips but the outside diameter of the pivot, this gives you the size of the circlip. Quote Link to comment Share on other sites More sharing options...
trailie Posted May 24, 2014 Report Share Posted May 24, 2014 (edited) The pivot pin is 11mm in diameter. I used circlips with an I.D. of 10mm when I made my pins. (check a few posts back for pictures.) If your really stuck PM me and I'll post you some. - Well having said that mine's a different model so maybe the shoes are not the same. Edited May 24, 2014 by trailie Quote Link to comment Share on other sites More sharing options...
bondy Posted June 5, 2014 Author Report Share Posted June 5, 2014 Thanks guys for your help. I also need the inturnal cir clip for the final end sleeve gear I was told its a special typ cir clip any body know if I can get 1 from any where? Quote Link to comment Share on other sites More sharing options...
