Beta 250 Rev '08' Carb
rhyds115
And there is no absolute exact setting, if there was there would be no reason to make it adjustable
Idle speed is quick and simple enough
The air screw is probably near 1.5 turns out, it's a sensitive adjustment but set the highest idle speed possible, start with full turns either way and listen carefully for changes in idle speed, then half turns, then quarter turns
Make sure the engine is at full operating temp and you may need to adjust it from time to time with altitude and temp
