dandabs Posted May 24, 2014 Report Share Posted May 24, 2014 I am going to TTC soon and am riding a Crf450x until I get there. Any drills I can be practicing on my bike that will help me? I was figuring stops and starts, balancing, figure eights...? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 25, 2014 Report Share Posted May 25, 2014 If you can balance your beast for a minute you are well on the way! Go through the TTC training tips and vids. I think you have the right attitude! Quote Link to comment Share on other sites More sharing options...
dandabs Posted May 25, 2014 Author Report Share Posted May 25, 2014 Thanks Line- When you practice balancing do you have the bike in 1st, clutch in and both brakes in? Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted May 25, 2014 Report Share Posted May 25, 2014 Try balancing with the bike off as you don't have the centrifugal force from the engine aiding you. Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 25, 2014 Report Share Posted May 25, 2014 Balancing with the engine on or off is good. Same with or without the brakes. Quote Link to comment Share on other sites More sharing options...
heffergm Posted May 25, 2014 Report Share Posted May 25, 2014 As mentioned, balancing. It's basically the same regardless of the bike, although the center of gravity is noticeably higher on an enduro bike. I'd say any training that makes you more proficient/controlled with clutch/brake/balance are all good. The hardest thing for me to get used to coming off enduro into trials is the slowing down part... sounds silly, but it's really tough to go slow, so practice that a lot. Quote Link to comment Share on other sites More sharing options...
dandabs Posted May 25, 2014 Author Report Share Posted May 25, 2014 Thanks all. Will do tons of balancing, can do that in the garage motor off. Quote Link to comment Share on other sites More sharing options...
mokwepa Posted May 26, 2014 Report Share Posted May 26, 2014 Good luck with the balancing . A crf is heeeeeavy compared to a trials bike. You will have to serious over exaggerate your movements to transfer it through to the bike. I recon you will be better off practicing throttle / clutch control by riding as slow as possible and attempting lock turns. Give it all ago....nothing to loose and any peg time helps. Quote Link to comment Share on other sites More sharing options...
dandabs Posted May 26, 2014 Author Report Share Posted May 26, 2014 Mok you're not kidding that CRF is an absolute tank! Quote Link to comment Share on other sites More sharing options...
mokwepa Posted May 27, 2014 Report Share Posted May 27, 2014 Can you balance it? Even just for a short bit? Curious if its actually possible. Ive never tried. Quote Link to comment Share on other sites More sharing options...
dandabs Posted May 27, 2014 Author Report Share Posted May 27, 2014 Barely! For a couple seconds...let me see how it improves Quote Link to comment Share on other sites More sharing options...
heffergm Posted May 27, 2014 Report Share Posted May 27, 2014 Can you balance it? Even just for a short bit? Curious if its actually possible. Ive never tried. I haven't found that balancing on my KTM is any different than on my trials bike for the most part... I'm equally bad on both. If I have the front wheel anchored in a small hole or against a rock, etc. both are easy, but on pavement it's a lot harder (for me). But like I said, I can balance either for about the same amount of time in the same conditions. Quote Link to comment Share on other sites More sharing options...
muddysump Posted May 31, 2014 Report Share Posted May 31, 2014 I tried googling it and it came up with yoga.....Whats the TTC training tips? Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 8, 2014 Report Share Posted June 8, 2014 http://trialstrainingcenter.com/how-to-ride-motorcycle-trials/introduction-to-tutorials/ Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted June 13, 2014 Report Share Posted June 13, 2014 Practice with tape. Practice getting caught in it and practice how to get it out of your tire. Also practice stretching and pushing it. Learning how to unwrap tape from the rear wheel in a section is a bit too late. I also practice jumping onto a step or a bench with two flat feet no bike. Generally when you jump up and onto something you are launching off on one foot. By unloading and jumping onto a step using two feet flat that will help you unload when riding the bike. I also tend to practice crashing quite a bit (aka Biffing it). I don't think its ever planned or intentional but I am really really good at crashing. How ever silly this sounds it really helps me when riding. I am usually ok trying something scrary now because I know that if I happen to crash I generally know how to handle the situation so that I am safe with the bike leaving functional. --Biff Quote Link to comment Share on other sites More sharing options...
