Sticking Auto Decompressor Mystery
bashplate
Hi folks,
went out practicing on the TLR200 on saturday, bike starting and running spot on. Then after about 1 1/2 hours I stopped to have a drink, went to restart....and....no go. this was due to the de-compressor being stuck open, so no compression. When I removed the decomp cable, the arm in the head returned to normal position and compression restored the bike started first kick. thought I'd better investigate and removed the clutch cover to see what the problem was.....found nothing obvious other than a wee chip/wear on the corner of the cam on the kicker shaft which operates the decomp. Cable was also free, so put it all back together and all is good. SO, any ideas, I'm hoping it was a fluke and won't manifest itself again in a trial!!!!!.
Cheers Trev
Hi I had much the same thing,
I tracked it down to the bolt that stops the shaft in the head coming out, having no copper washer under it .
When it was cold it was fine when it got warm it would hold tighten up on the shaft causing it to grab the shaft just enough to stop it rotating .
  • 1 month later...
  • 2 months later...
I can say only something about the combination of copy carb+ cherry bomb header from shedworks + exhaust from WES + K&N in airbox: elastic and powerful reving from idle, absolutely no low rev stalling, but a little bit tiredly at high revs. Imho very good for vintage trial riding.
