blast_off Posted June 17, 2014 Report Share Posted June 17, 2014 New moto trials rider. 2006 Beta Rev3. I'm trying to get the rear wheel off the ground to do some endos and whatnot. I'm not finding the power I really need to get this done. I've tried "jumping" like I've read in a different thread, but it doesn't seem to happen. I can nose wheelie and endo a bicycle with ease, using one finger on the brake. The only way i'm able to get enough power on the moto is to use two fingers and pull really hard. As I'm new to moto trials I'm wondering if the front brake needs maintenance? Or is this just a technique thing? The pads look thick and everything looks clean. Plenty of fluid too. Is it common to need two fingers or should one light pull be enough? Beta stock brakes. Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 18, 2014 Report Share Posted June 18, 2014 The pads have likely been trashed with oil or some other chemical. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 18, 2014 Report Share Posted June 18, 2014 get a bucket of water. ride around with the front brake on until it gets real hot then douse with aforementioned. If this improves it then bingo if just a bit better try again then if that doesnt fix it then dig deeper. Not forgetting that the technique required is to compress suspension AND apply brakes. Quote Link to comment Share on other sites More sharing options...
blast_off Posted June 18, 2014 Author Report Share Posted June 18, 2014 (edited) I will try this and report back, thanks! UPDATE: This worked somewhat! I went through two cycles, and had the rotor sizzling. The rotor changed color too; dark chrome now. I can definitely get the rear wheel off the ground with one finger now! Thanks! Edited June 20, 2014 by blast_off Quote Link to comment Share on other sites More sharing options...
