smelling123 Posted June 18, 2014 Report Share Posted June 18, 2014 Could anyone please post a picture of the alloy head steady used on some of the 199bs? I need a shot with the tank off showing the front frame mount. I have the standard pressed steel one - were the alloy ones better? - looks stronger with 3 fixing points? many thanks Quote Link to comment Share on other sites More sharing options...
woody Posted June 18, 2014 Report Share Posted June 18, 2014 (edited) Just happens I have these which I took for someone else a while ago. No idea if they are better or not. You also need to make the T shaped bracket that fits between the two rear head studs as the bottom head steady mount bots to this Edited June 18, 2014 by woody Quote Link to comment Share on other sites More sharing options...
breagh Posted June 18, 2014 Report Share Posted June 18, 2014 As a side issue my Bultaco doesn't have one,how critical is it to have one fitted. Thanks for any replies in advance. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted June 18, 2014 Author Report Share Posted June 18, 2014 Thanks Woody, mine doesnt have the braket welded on the frame so may have to improvise... Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 19, 2014 Report Share Posted June 19, 2014 There were some with and some without think that 3000 frame numbers onwards had them mostly. IMHO much better than the steel ones, 3 point fixing. the frames bent with the steel ones rarely with the ally but they have to be ridden hard to cause deflection. Quote Link to comment Share on other sites More sharing options...
bondy Posted June 19, 2014 Report Share Posted June 19, 2014 my 199B has the pressed steel 1 but has a steel rod weled on the under side to strenghthen it. i do think the alloy is better as nigel says they are stronger plus if you need to take the engine out theres no need to unbolt the cylinder head. unless your doing work on the top end. but i think with mine its strong enough with the steel rod welded on. Quote Link to comment Share on other sites More sharing options...
