Headset Bearing
ao7971
Does anyone have any tips on how to remove the bottom bearing off the steering stem when it is siezed o n? Other than the big hammer and chisel idea!
Hello ao7971,
Tried a "cold spray " as used for computers?
A radical way if you have to replace it: use arc welding: 2 or 4 dots where the balls run will make the steel retract.It does work, I've done it. I hope this will help you .
The idea of putting a couple of small weld runs does work very well. If nothing else, the heat makes the parent metal go brittle and crack easier when tapped. Although usually the heat from the weld is enough to make the outer race go loose.
