coulda_dun_better Posted June 22, 2014 Report Share Posted June 22, 2014 So I finally sold my 4rt abd bought a sherco!! So are there any hints and tips with regards to maintenance or quick mods that may not have been done?? Also what mixture do you run the fuel on? Thanks in advance Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted June 22, 2014 Report Share Posted June 22, 2014 i think the lack of response means that most folk are in shock that you have gone from a 4rt to a sherco , 70 to 1 should be fine , and check the bike fully after every ride for fallen off or broken parts Quote Link to comment Share on other sites More sharing options...
dadof2 Posted June 22, 2014 Report Share Posted June 22, 2014 Handbook says 50:1 fuel:oil ratio On any secondhand bike I would strip and grease every bearing. Even wheel bearings can be cleaned out and greased by prising the seal out with a watchmakers screwdriver. Clean the bearing (still in wheel) with your fuel, let it dry, put new grease in then press the seal back in. Change all the hydraulic fluids and preferably strip, clean and flush out all the hydraulic parts. Quite a few Sherco hydraulics have been found to contain metal debris or have sharp edges on the holes in the cylinders which chew up seals. Where any hole enters the bores polish any sharp edges off very carefully with fine or medium steel wool. Other than above its typical servicing. Quote Link to comment Share on other sites More sharing options...
taffe Posted June 22, 2014 Report Share Posted June 22, 2014 Hi, what I did when needing info was to search back through the wealth of info in back posts on this forum [and others]. I got a much more varied list of comments and ideas. I printed many of these and put them in a folder for later reference. Cheers Taff Quote Link to comment Share on other sites More sharing options...
