lockie28 Posted June 30, 2014 Report Share Posted June 30, 2014 hi. Is there a specific way to remove the kickstart on a txt pro 2010 ... My kickstart seems to be in the wrong possition so had a bash at removing it last night, took out all the bolts holding it in ect ect but it is well and truely stuck on the shaft !! any tips would be gratefull , cheers in advance. Ian Quote Link to comment Share on other sites More sharing options...
djdenzil Posted June 30, 2014 Report Share Posted June 30, 2014 Had the same problem on my 2013 Factory. Put plenty of ease out fluid all around the knuckle joint, leave to soak for 24 hours. Remove kick start to leave the knuckle joint, do not level against casing as it may crack and that's £100 to replace. What you need is a two leg puller to side behind, use an allen bolt and screw/pull off. A couple of taps before you start seems to loosen the seizure. Apply plenty of copperslip before you re-assemble. Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 30, 2014 Report Share Posted June 30, 2014 You loosen the bolt slightly (Do not remove) Then just open the kick start. It basically will pry it self off. Fast and easy once you have done it. 1 Quote Link to comment Share on other sites More sharing options...
jordi Posted June 30, 2014 Report Share Posted June 30, 2014 You loosen the bolt slightly (Do not remove) Then just open the kick start. It basically will pry it self off. Fast and easy once you have done it. As above, its simple once you realise. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted July 1, 2014 Report Share Posted July 1, 2014 Thats THE way yes! Quote Link to comment Share on other sites More sharing options...
