heffergm Posted July 1, 2014 Report Share Posted July 1, 2014 It's probably time for me to dump the fork oil in my '13 Evo, and the manual is horribly unclear as to how to measure the level. I'm guessing it's spring in, fully compressed, then measure from the top of the tube to the oil, but was looking for confirmation. Quote Link to comment Share on other sites More sharing options...
mags Posted July 1, 2014 Report Share Posted July 1, 2014 (edited) I had a peek at my '14 Beta 4T manual for comparison. It says on fork re-oil page to pour in quantity listed on page 11.... go to page 11 and it says .... Oil level (mm) (edge rod fork compressed) right leg 65, left leg 125 So I take that to mean.... Fork leg vertical, fully compressed, fill with oil until it just touches bottom of a steel rule with the rule at 65mm mark at top edge of fork. If using a small 6 inch (150mm) rule tie some string through hole in end in case it falls in .... don't want to have to start again! Be nice if it was a quantity, that way you could just use a graduated plastic lab flask, measure and drop in? But it looks like thats not the case... have to measure from top of leg to oil level? Confirmation is easy.... remove leg.. open and compress... measure to oil level and check with manual's listed measures??? Mags Edited July 1, 2014 by mags Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 1, 2014 Report Share Posted July 1, 2014 It`s spring out, always has been when taking a measurement. It actually says take the spring out dump the oil and refill. Remember it is a translated version. 1 Quote Link to comment Share on other sites More sharing options...
dannyb Posted July 4, 2014 Report Share Posted July 4, 2014 (edited) What oil does everyone use ? Different weights for the different legs? Edited July 4, 2014 by dannyb 1 Quote Link to comment Share on other sites More sharing options...
