steam Posted July 1, 2014 Report Share Posted July 1, 2014 The front brake on my 2008 Rev 3 grabs at low speed and locks wheel. Any ideas on a fix? Quote Link to comment Share on other sites More sharing options...
0007 Posted July 1, 2014 Report Share Posted July 1, 2014 It's such a basic system that the problem will be visual Is there more history? Brake pads worn to steel at some point and damaged the disc? Bike modified with different master? Normal looking parts won't do it here must be more to the story Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 1, 2014 Report Share Posted July 1, 2014 Bent disc, no free play, pad issue. broken spring in master cylinder. I have also seen the lever bolt too tight and when brake used it would keep the wheel locked. Quote Link to comment Share on other sites More sharing options...
