clasico Posted July 2, 2014 Report Share Posted July 2, 2014 Being new to betas i'm finding that my son's rev 3 125 fan rarely enters into action. Is that normal? The bike perfons ok and doesn't seem to overheat nor loses power but my gas gas fan runs much earlier and more often. What is your experience with beta fans? Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 3, 2014 Report Share Posted July 3, 2014 This time of year it should not be much different depending on who is riding it. Some times when a fan is just starting to go bad you can actually push start it. (Spin it with your finger) Quote Link to comment Share on other sites More sharing options...
slicktop Posted July 3, 2014 Report Share Posted July 3, 2014 The fan on my 300 does not run as much as I would expect. My Husky WR is the same . The fan only comes on when run hard. Quote Link to comment Share on other sites More sharing options...
hoggyf Posted July 3, 2014 Report Share Posted July 3, 2014 Not sure if this is any use but my Rev 3 the fan comes on usually by the end of the first section and will stay on most of the day, my Rev 4 the fan cuts in and out on a regular basis and you can really tell when it cuts in by the amount of hot air blasting out, neither over heat or do anything odd, only the rider does odd things lol Quote Link to comment Share on other sites More sharing options...
