2013 Gas Raga Rieger Rear Shock Adjustment
thomastomsk
I have just bought a 2013 300 raga to replace my 2012 one and when I went to set the rear shock up I found that it was upside down compaired to the 2012 raga,ie the compression is at the bottom not the top and I am finding it hard to adjust it because of the linkage,is there an easy way or do I have to take the shock off to adjust the compression thanks for any info kind regards tommy
  • 3 weeks later...
Hi Thomas, this is a bit late I know.
I have a 2011 Raga with the Reiger shock. I find it's very easy to adjust. For the bottom adjustment, I just go in with a long screw driver (about 8 inch). It goes just below the swing arm and just above the left dog bone (that's with the bike supported on a stand). The top adjuster is easy using the special tool that should have come with the bike.
Chris.
