Electronic Ignition
darrenc
has any body put electronic ignition on a 250t ?
this bike has motoplat ignition and can't get the timing right it fire ring about 10 deg before TDC and now more movement on the back plate .
Thank Darren
Hi Darren. The best way to time an Italjet is to use a multi meter and a dial gauge. You hook the multi meter up to the black ignition wire going to the coil and to earth and put the dial gauge in the spark plug hole and get the points to start to open at 2.7mm BTDC. You will see on the multi meter when the points start to open. I hope this helps you out. Graham.
