ric h Posted July 13, 2014 Report Share Posted July 13, 2014 The rear wheel needs a new bearing.There is only a bushing and an oilseal on the other side.Anyone have this bushing out? Quote Link to comment Share on other sites More sharing options...
toetoe Posted July 13, 2014 Report Share Posted July 13, 2014 I took mine out not so long ago, quite a few people on here suggested tyre levers but mine wouldn't budge so i used, i think it was 16mm, raw bolt and taped it out from the other side, it came out a treat. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted July 13, 2014 Report Share Posted July 13, 2014 I don't have any good tips (a heat gun on the hub may help) but I understand there is an upgrade kit to change to a full bearing like the later bikes. Mark Quote Link to comment Share on other sites More sharing options...
canada280i Posted July 13, 2014 Report Share Posted July 13, 2014 I think it is a bearing and spacer kit to replace the bushing, carrier centres should have one in stock. The only time I saw one removed involved heat and prying but drifting it out with a bolt sounds the easier option Quote Link to comment Share on other sites More sharing options...
