bambam_n_chunx Posted July 16, 2014 Report Share Posted July 16, 2014 Anyone help setting up the points and atu on my side points cub. I had to split the motor to replace the kick start pawl, thats done but the atu and points arent right as ive a spark but dont know how to set it right. The haynes book seems to be written in imperial too LOL Quote Link to comment Share on other sites More sharing options...
jon v8 Posted July 17, 2014 Report Share Posted July 17, 2014 Blimey,you must be the last person in the world trying to get a Cub to run on points ! Electronic ignition must have saved loads of owners working a sledgehammer into them.... Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted July 18, 2014 Author Report Share Posted July 18, 2014 I know but the thing is ive just found this trials cub after its been stood for 20 yrs. I wanted to make sure all was well with the motor before I start to give it a bit of a makeover to use. What you guys think? Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted July 18, 2014 Author Report Share Posted July 18, 2014 The timing is now sorted through a days trial and error, not sure if its spot on but its running and sounds some where near. I`ll be fitting a pvl or similar set up once ive had the work on the chassis done. Ive been advised to sort swingarm and have wheels respoked before using it and I might see if I can have the forks looked at as they seem a bit dead. 1 Quote Link to comment Share on other sites More sharing options...
