Tl320 Leaking Gearbox Oil
mudyman
Hi all
I have 2 TL320´s that are both leaking oil from the kickstart shaft / gear change shaft. They both have had the seals changed and the Oring for the gear lever changed. Sometimes they drip a lot from the gear change shaft and sometimes a bit from the kick start shaft. Other days they don´t leak at all. If the bikes lean away fromthe shat´s they usually stay dry (shame that the side stand is on this side). Any tips welcome !
