akexd Posted August 3, 2014 Report Share Posted August 3, 2014 Hi I am trying to fit a landyard kill switch on my gas gas 2002 trials. But it is working the opposite way as if it was a push kill switch. When the plug is in it stops and should be other way round.!! I have tried all ways i can imagine. Am i missing something really obvious? Any ideas please would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted August 4, 2014 Report Share Posted August 4, 2014 It sounds like your switch is wired opposite of how the bike is wired. Some bikes use "normally open" kill switch, some use "normally closed." Normally open would mean there is no connection to ground (earth) until you press the switch (close the circuit). I think GasGas uses "normally open." I know the JT25 I had was wired that way. Does the switch have 3 possible places to connect wires? One would be "common", one "normally open" and one "normally closed." Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted August 5, 2014 Report Share Posted August 5, 2014 One side should be grounded to the frame and the other to the kill wire on the ignition CDI box. Is this a Pro or TXT? If you have both wires to the CDI then that would be the issue. --Biff Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted August 20, 2014 Report Share Posted August 20, 2014 Like said above there are two ways of killing the engine. Makeing ground to the cdi, so 1 wire to cdi other to frame/ground. (this if it is a connecting kill switch). The other disconnects, than you need a wire to cdi to kill the engine Quote Link to comment Share on other sites More sharing options...
