Ty250 Fork Question
badmotofo
My forks have been apart for a couple of months and I am not positive how the front fork is reassembled. Could someone confirm? Right now I have the damper inside the slider and extending through the bottom of the slider. The small spring and aluminum cap are then put onto the damper and the unit is inserted into the outer fork. I tried it with the small spring inside the slider but the slider would dig into the aluminum cap.
Thanks,
