Pinging
burnleytazz
Hi all ive just put engine back together on my txt pro 2002 after a crank rebuild and my engine is pinging
call me stupid but think i may of advanced my timing
which way do you turn the stator to retard it slightly
Edited by burnleytazz
Have you checked the squish clearance when refitting cylinder head?
Crank rebuild - did this include new connecting rod?
Leak test, You need to blank off inlet with blanking plate / bung. Leave the reeds in but prop them open. Fit a blanking plate to exhaust outlet on barrel with tyre valve in it and pressurise engine to between 5 and 10 PSI and see if it drops over a few minutes period.
cheers dad at wotk at min but wen i get bk ill recheck squish and yes new rod
ill be honest wen i rebuilt engine and started it i mistaken the pinging for piston slap as i didnt know anything about detonation so i rang gas gas up they said keep ading base gaskets which altered the port timining is this the reason for it overheating what happens wen u raise cylinder cheers again
  On 8/13/2014 at 11:40 AM, burnleytazz said:
sorry about my english grammer can you tell i missed alot of school :stoned:
Didn't they tell you it's the effort you put in to it that counts? :huh:
Edited by guys
