chappo Posted August 17, 2014 Report Share Posted August 17, 2014 Hi everyone, still on with my rebuild of the 248 and I'm having trouble sourcing a felt pad that sits on the stator plate to wipe the flywheel cam. I'm in Lancashire, UK. Ps. Tried Inmotion UK ..........no joy. Regards. Dave. Quote Link to comment Share on other sites More sharing options...
johnmartin247 Posted August 18, 2014 Report Share Posted August 18, 2014 Could you not make something up? I would think that you might struggle to find that as a spare part. Good luck with the search anyway. Quote Link to comment Share on other sites More sharing options...
bullylover Posted August 18, 2014 Report Share Posted August 18, 2014 Why not just make one? A piece of foam from under your ironing board would probably also work. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 18, 2014 Report Share Posted August 18, 2014 you can buy felt pads from hardware stores for putting under the legs of furniture 1 Quote Link to comment Share on other sites More sharing options...
johnmartin247 Posted August 18, 2014 Report Share Posted August 18, 2014 you can buy felt pads from hardware stores for putting under the legs of furniture Good idea, you can buy commercial double sided sticky tape which sticks great to metal surfaces and the felt would take well to it as well. Quote Link to comment Share on other sites More sharing options...
chappo Posted August 18, 2014 Author Report Share Posted August 18, 2014 Thanks guys, what I didn't mention was that the felt pad has worn through and then the cam has worn through the metal strip that supports the felt pad so theres nothing to support a new piece of felt. I understand guys that these things are going to be likes hens teeth and i'm probably going to have to manufacture something, thanks for your help. Regards Dave. Quote Link to comment Share on other sites More sharing options...
