dieseltwitch Posted August 18, 2014 Report Share Posted August 18, 2014 So I just replaced my throttle cable on my 06 TXT 300. Now when i go full lock to the right to work on my balancing my motor revs high. I'm thinking I wither installed the cable wrong or I adjusted it wrong or its routed wrong. Any one have photos of how it should be routed. I didn't think to look close at how it should have been routed when I took the old one off? how should it be adjusted? Im new to trials so bare with me. Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 18, 2014 Report Share Posted August 18, 2014 It routes along the left frame from the carb. It comes past the steering head from the left and crosses through the middle of the forks to the throttle tube. It is very easy for the cable to pull out and cause this on any bike. Good luck. Quote Link to comment Share on other sites More sharing options...
wakka Posted August 19, 2014 Report Share Posted August 19, 2014 Raga throttle cable is longer than a std txt, as I,ve seen both from our gasgas guru in nz the long fits my 09 Raga with a Keihin carb as std ome part cheers Wakka Quote Link to comment Share on other sites More sharing options...
