mike350 Posted October 3, 2014 Author Report Share Posted October 3, 2014 Hi All, I said that I'd report back once I'd ridden the bike properly. This is with the Inmotion kit, without lights. Well, first thing is I'm surprised that it still kicks back a fair bit. Not a bother, but it's obviously timed very near TDC at low revs. She's a little slow to find revs right at the bottom end - but this is down to me trying to keep an original Bing carb, rather than fitting the brand new Mikuni that I have in the box. None the less, the bike is running brilliantly, even at the top of long climbs in tight sections around trees in second where the revs dropped very low, she keeps pulling. And opened up on those climbs it has amazing power, running very clean indeed with lovely pick up. All in all, I have to say that I'm delighted with my investment. Highly recommended. Now to fit that carb.... 6 Quote Link to comment Share on other sites More sharing options...
woody Posted October 3, 2014 Report Share Posted October 3, 2014 On 10/3/2014 at 7:46 AM, mike350 said: She's a little slow to find revs right at the bottom end - but this is down to me trying to keep an original Bing carb, rather than fitting the brand new Mikuni that I have in the box. That's due to the ignition, it makes them a bit lazier off pilot. 1 Quote Link to comment Share on other sites More sharing options...
lbhbul Posted October 3, 2014 Report Share Posted October 3, 2014 Mike, when you replace the Bing and get it jetted spot on you should see an improvement in performance and usually greater fuel economy in my experience. Really a nice looking A model. Larry 1 Quote Link to comment Share on other sites More sharing options...
lbhbul Posted October 4, 2014 Report Share Posted October 4, 2014 (edited) Everyone should experience timing a BUL at least 1 time as it is so much fun!! I still do it as I don't really find it necessary to set them often. The cam must be as smooth as possible, and whatever ignition, the case must be vented and not sealed. MIKE, The polished cases really set the bike off. Larry Edited October 4, 2014 by lbhbul 1 Quote Link to comment Share on other sites More sharing options...
