feetupfun Posted May 26, 2018 Report Share Posted May 26, 2018 On 5/24/2018 at 9:56 AM, guy53 said: David, do you feel that the Majesty Damping Rod are better on rock bed and rough downhill than the Gold Valve ? Guy Expand I'm still undecided Guy. The Majesty damper rods make the front end feel less busy than standard TY on stream bed rocks. The gold valves feel like the front suspension is more supple than with the Majesty rods and they provide an equally good (calm) feeling to the front end. Overall both make for a more relaxing ride in rocky stream beds compared with standard but I can't decide which is better. I find the Majesty rods make the front suspension action feel similar to a Bultaco front end. As for rough downhills with the front end loaded up, the Majesty rods work very well straight out of the box. The gold valves require careful setup to get the right balance between compression damping and fork spring rate and fork spring pre-load to be as good as the Majesty damper rods when riding rough steep downhills but are just as good for this when set up. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 26, 2018 Report Share Posted May 26, 2018 Custom rear sprocket carrier 520 chain Swingarm protector Chain tensioner retained by a screw Aluminium snail cams Aftermarket shift lever Rear wheel axle Standard-looking carby I still like that seat Be careful that the ignition cables don't get damaged by the heat from the cylinder fin Looks like you've made the new exhaust header Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 26, 2018 Report Share Posted May 26, 2018 (edited) Haven't done the exhaust header yet but it has been repaired with some fairly heavy pipe at some stage End of the chain tensioner mount had been cut & tapped at some stage Both axles are 17mm aluminium, front threads into the fork leg as per the newer bikes I plan on cutting & lengthening the ignition wires when time permits so that they run along the frame, looks tidier & as you say gets them away from the cylinder Carb is standard except for #37.5 pilot jet & #200 main jet. The base of the airbox has had the step at the bottom removed & the filter is now at the top like the modern design of airbox so it breathes quite a bit better. I did think the #200 would have been too big but so far it seems right, it was originally fitted when the motor was worn out & sucking air through the crankseals Edited September 12, 2018 by tony27 1 Quote Link to comment Share on other sites More sharing options...
majesty Posted June 1, 2018 Report Share Posted June 1, 2018 Couldn't find a dedicated Majesty thread, so I thought I'd post some pics of my Majesty 320............ 8 Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted June 2, 2018 Report Share Posted June 2, 2018 Very nice 1 Quote Link to comment Share on other sites More sharing options...
tytrials28 Posted June 12, 2018 Report Share Posted June 12, 2018 (edited) Purchased this and cleaned it up a bit. 1977 TY250250 Edited June 14, 2018 by tytrials28 6 Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 16, 2018 Report Share Posted June 16, 2018 Ignition cover is 74 model which is not unexpected. Very correct looking bike apart from that Quote Link to comment Share on other sites More sharing options...
littel Posted August 10, 2018 Report Share Posted August 10, 2018 On 12/5/2014 at 10:26 PM, kanur said: Here's a couple pics of mine. I've added Sammy Miller Betor trials shocks since these pictures were took. Expand What is the head off of ? 1 Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 11, 2018 Report Share Posted August 11, 2018 DT250b/c, I did the same to mine after seeing these photos. Gives a different look to the motor but weighs quite a bit more than the original. Compression may be slightly higher but not by a huge amount if it is A small amount of trimming of the fins is needed for the exhaust to clear the head, I also took about 10mm off the rear to blend the head to the cylinder fins properly 1 Quote Link to comment Share on other sites More sharing options...
thai-ty Posted August 14, 2018 Report Share Posted August 14, 2018 Was in the UK back in April / May on holiday with the family. As well as buying a genuine Yamaha w/shop manual and a crank pullerer-inner w/shop tool, some smooth new Venhill clutch cables, i picked up some universal front mudguards, cut the flap off the rear, drilled some holes and reversed them. Look smarter, shorter and more modern than stock. Also picked up two of Paul Cowley's Shedworks sexy-as-hell tank shelters i had ordered, and two plastic tanks i won on Ebay. Lucky we had 3 suitcases.......... Quote Link to comment Share on other sites More sharing options...
thai-ty Posted August 14, 2018 Report Share Posted August 14, 2018 2 Quote Link to comment Share on other sites More sharing options...
scot taco Posted August 15, 2018 Report Share Posted August 15, 2018 Very Nice looking TY monos thai-ty. I had a 350 that I should have kept,but it was near impossible to find a piston kit so I sold it.They are hard to find here and the 250 is even more rare. Quote Link to comment Share on other sites More sharing options...
thai-ty Posted August 20, 2018 Report Share Posted August 20, 2018 On 8/15/2018 at 4:29 AM, scot taco said: Very Nice looking TY monos thai-ty. I had a 350 that I should have kept,but it was near impossible to find a piston kit so I sold it.They are hard to find here and the 250 is even more rare. Expand Thanks, yeah they never had the 250 mono officially in the States, and we never got the 350 officially in Europe. By all accounts the 250 was a better motor, and sold a lot more numbers worldwide. Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 20, 2018 Report Share Posted August 20, 2018 I had a 350, lots of chrome missing from around the exhaust port mainly so it rattled a fair amount but still ran well. Felt like being halfway up a ladder until I lowered the pegs, did my own disc brake conversion for the front wheel. Disappeared from sight after I sold it to upgrade to a 95 Gas Gas JT350, as far as I know it hasn't reappeared in the last 20 years 1 Quote Link to comment Share on other sites More sharing options...
sdm Posted August 23, 2018 Report Share Posted August 23, 2018 Here is my 76 175 that followed me home after an event... I just got the engine back together after sending the crank out for a new rod,mains etc and a fresh bore and piston. A friend did a nice job on the tank and exhaust guard and I resprayed the frame. Lots of small bits to get it back to reliable running and I have about 2 hours break in so far. Loving the light weight and handling. 2 Quote Link to comment Share on other sites More sharing options...
