newtrialer Posted August 21, 2014 Report Share Posted August 21, 2014 (edited) Hi guys, ive recently purchased this bike, anyway it has a engine rattle that is constant and rpm dependant but oddly and confusingly it entirely goes away when the bike is leant over a little bit to the left. If you stand it upright or lean it to the right it just remains the same..?? The bike runs like it should apart from the noise (which sounds like a bad top end rattle). Please can anyone shed any light on this?? Edited August 21, 2014 by newtrialer Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted August 22, 2014 Report Share Posted August 22, 2014 Does the noise go quieter or stop when you pull the clutch lever, if so its the usual Gag Gas 'character' that goes hand in hand with the sensation of the engime falling out when changing gear from 4th to 5th. Quote Link to comment Share on other sites More sharing options...
newtrialer Posted August 22, 2014 Author Report Share Posted August 22, 2014 Hi there, thanks fir your reply but it is in no way affected by the clutch, im really stuck with this one lol any other ideas? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted August 22, 2014 Report Share Posted August 22, 2014 Complete guesses Clutch touching engine case Kick start idler gear Quote Link to comment Share on other sites More sharing options...
power175 Posted August 22, 2014 Report Share Posted August 22, 2014 Is it the bearing or something loose catching inside the engine. -power175 Quote Link to comment Share on other sites More sharing options...
proc Posted September 7, 2014 Report Share Posted September 7, 2014 Had same bike myself with exact same noise was basically exactly as you describe had it in bits rebuilt and still did it just put it down to character of bike Quote Link to comment Share on other sites More sharing options...
