jordi555 Posted August 27, 2014 Report Share Posted August 27, 2014 My boys 2013 80 is great apart from the tick-over, it seems to need increasing as it gets hotter the longer he rides it. At the weekend in the space of a 2 hour practise I had to adjust it 4 times. Anyone have an idea what's going on with it ?? Quote Link to comment Share on other sites More sharing options...
nelly1 Posted August 27, 2014 Report Share Posted August 27, 2014 my daughters 08 is very similar tickover all over the place no ideas myself Quote Link to comment Share on other sites More sharing options...
welsh beta Posted August 27, 2014 Report Share Posted August 27, 2014 My beta 250,2010 has been the same.remove the petrol tap,clean the filter on the tap and clean the carb.my bike has never been better.also check the play in the throttle cable.like a said my bike is a 250 and these issues might be differance on the beta 80,got to be worth a try.... Quote Link to comment Share on other sites More sharing options...
jordi555 Posted August 28, 2014 Author Report Share Posted August 28, 2014 My beta 250,2010 has been the same.remove the petrol tap,clean the filter on the tap and clean the carb.my bike has never been better.also check the play in the throttle cable.like a said my bike is a 250 and these issues might be differance on the beta 80,got to be worth a try.... I'll try the tap clean as I've pretty much done everything else, cleaned carb, cleaned air filter and now only lightly oil it, and fitted a new iridium plug Quote Link to comment Share on other sites More sharing options...
fatjacko Posted August 28, 2014 Report Share Posted August 28, 2014 On the basis that the carb is the same as a 2010 EVO 80, then yep the best thing is to strip and clean, make sure the float level is right and that tends to do the trick. Factory float level seems to leave the bike short of juice at times. 19mm float gap seems to be general idea but someone with more experience than me could confirm. Quote Link to comment Share on other sites More sharing options...
