arun1664 Posted August 13, 2005 Report Share Posted August 13, 2005 (edited) I am asking on behalf of a mate who has a 350 Sherpa and has heard of a Mikuni conversion. Does anybody have any experiance of the change, what carb model it uses, what the jet sizes are and most importantly whether or not its worth bothering with ? Thanks in advance, Mike Edited August 13, 2005 by arun1664 Quote Link to comment Share on other sites More sharing options...
arun1664 Posted August 13, 2005 Author Report Share Posted August 13, 2005 Thanks Big John, he has already spoken to Dave Renham who doesn't do anything other than the standard Bing. Quote Link to comment Share on other sites More sharing options...
woody Posted August 13, 2005 Report Share Posted August 13, 2005 Allens in Bingham Notts. tel 01949 836733 sell Mikunis and I think have the jet sizes for Sherpas so worth a try. Can't speak from experience as to what difference it will make but a new Mikuni is sure to be an improvement on a used Bing or whatever is fitted at the moment, but by how much and whether it is a worthwhile mod I can't say. Quote Link to comment Share on other sites More sharing options...
dabdab Posted August 13, 2005 Report Share Posted August 13, 2005 Allens in Bingham Notts. tel 01949 836733 sell Mikunis and I think have the jet sizes for Sherpas so worth a try.Can't speak from experience as to what difference it will make but a new Mikuni is sure to be an improvement on a used Bing or whatever is fitted at the moment, but by how much and whether it is a worthwhile mod I can't say. <{POST_SNAPBACK}> <{POST_SNAPBACK}> I have successfully fitted a FLAT SLIDE Keihn carby to my M199A- same as that sold as an option on Sherco. It's a little complex, in that I had to have a machine shop add a larger rear spigot fitting(to match the airbox rubber) but that carby is capable of really fine tuning, and here in Oz jets are readily available and the carbs are cheaper than Mikunis. If you want jetting details, post a response Quote Link to comment Share on other sites More sharing options...
munch Posted August 14, 2005 Report Share Posted August 14, 2005 dabster is on holiday Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 24, 2005 Report Share Posted August 24, 2005 back now. There may be some slight advantage with a mikuni but I would be sceptical if it is anything more than slight. the only problem with the bings is slide wear. If thats ok in the body and newish jetted standard and set lean on the float the carb is very sound and was never swapped at the time. Don't think fitting a mikuni will transform the bike because this just won't happen. If everything else is 100% and time is no object then I wouid give it a go, but is it spot on everywhere else? Quote Link to comment Share on other sites More sharing options...
arun1664 Posted August 25, 2005 Author Report Share Posted August 25, 2005 Thanks Mr Dabster & others, will pass the comments on to my mate Quote Link to comment Share on other sites More sharing options...
lms 6201 Posted August 25, 2005 Report Share Posted August 25, 2005 www.bjracing.com sell mikuni carb conversion , has adaptors and they jet to suit (so they say anyway) Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 26, 2005 Report Share Posted August 26, 2005 Jet to siut will only work if they have experience of Sherpas, I doubt it. Quote Link to comment Share on other sites More sharing options...
