Rear Brake Cam
bondy
hello all anybody had problems with the rear brake plate cam being loose the hole as worn over time so the cam Arm wobblie iv'e heard you can have them sleeved out to stop this but is there any other tricks you guys use? cheers bondy.
Edited by bondy
Bondy, If the looseness doesn't cause binding then lube it lightly and go on down the road, but if you want to fix
it properly then ensure the cam shaft is not worn and have a machinist bore & bush the backing plate to repair.
Probably expensive.
Larry
nice 1 trialsrfun iv'e sent the brake plates off to be re sleeved not a bad price. i will look into getting the hubs relined but there ok for now. cheers bondy i will post photos off before and after iv'e had the brake plates done.
