tom675 Posted September 18, 2014 Report Share Posted September 18, 2014 Any advise on the best ways to improve the feel and running of a 315? Quote Link to comment Share on other sites More sharing options...
johnmartin247 Posted September 18, 2014 Report Share Posted September 18, 2014 What is the problem with the feel and running of the bike in particular? Quote Link to comment Share on other sites More sharing options...
tail Posted September 18, 2014 Report Share Posted September 18, 2014 Carb upgrade to either the Keihin pwk 28mm or 26mm Quote Link to comment Share on other sites More sharing options...
tom675 Posted September 18, 2014 Author Report Share Posted September 18, 2014 Bike feels heavy, iv ridden a few 4rt that are meant to be similar weight, yet feel lighter and more agile. brakes could do with sharpening up too its running stadard del carb, it it worth trying to set this up perfectly or is a carb upgrade a better option? Quote Link to comment Share on other sites More sharing options...
lewis315r Posted September 18, 2014 Report Share Posted September 18, 2014 H & D Racing rear linkage upgrade! Super simple bit of kit and really improves the way the bike rides!! Quote Link to comment Share on other sites More sharing options...
tom675 Posted September 18, 2014 Author Report Share Posted September 18, 2014 Yep lewis I agree, rear end feels fine as I have those fitted, its the front that feels numb, may just be suspension settings, need to find a rough guide for setup Quote Link to comment Share on other sites More sharing options...
bilks Posted September 18, 2014 Report Share Posted September 18, 2014 (edited) Try link, might find something of interest. http://montesacota315.com/en/ might not lol. Edited September 18, 2014 by bilks Quote Link to comment Share on other sites More sharing options...
barnesy Posted September 19, 2014 Report Share Posted September 19, 2014 what year is the bike? they got better every year. Albea motors sell a racing kit which should have everything you need, they may not ship to UK but you should be able to source most things over here... http://www.albeamotors.com/catalog/montesa-cota-315r-74094 Ta B Quote Link to comment Share on other sites More sharing options...
tail Posted September 19, 2014 Report Share Posted September 19, 2014 The carb upgrade makes the bike a lot more alive Quote Link to comment Share on other sites More sharing options...
tom675 Posted September 19, 2014 Author Report Share Posted September 19, 2014 Bilks I found that site late last night. It seems helpful It's year 2000, first Showa model. Stock bike apart from newer twin pot front caliper, h&d dog links and 2004 plastics Quote Link to comment Share on other sites More sharing options...
barnesy Posted September 19, 2014 Report Share Posted September 19, 2014 2000 models had the older delorto's, 01 onwards have phbl fitted as stock so you may want to look as mentioned at carbs.. ta B Quote Link to comment Share on other sites More sharing options...
tom675 Posted September 20, 2014 Author Report Share Posted September 20, 2014 Ye mine has the older del on are parts still available for a full engine rebuild, engine is knocking unfotunatley, unsure on whether its top or bottom as havnt looked into it as its always had a slight knock but recently gotmore noticable also is it possible to convert to fat bars without having to buy expensive new top yoke clamp? Quote Link to comment Share on other sites More sharing options...
tail Posted September 20, 2014 Report Share Posted September 20, 2014 Most knocking is the bottom of the piston slapping against the bottom of the sleeve, because they have 3 rings it holds the top of the piston but the bottom does tend to slap Sandifords do the piston and all gaskets for £140 Quote Link to comment Share on other sites More sharing options...
chuck4788 Posted September 21, 2014 Report Share Posted September 21, 2014 For a starting place on the Showa forks turn the clickers full out (CCW). Also a PO may have put the wrong oil in the forks, or too much. The oil for the right leg should be cartridge fork oil, a very thin oil. Showa SS05 or Honda SS05 fork fluid or similar. No cartridge in the left leg so the oil just lubes the bushings. The level in both legs determines the resistance to bottoming, standard level is 39mm from the top with the fork fully compressed. The Owner's Manual covers all of the above. Quote Link to comment Share on other sites More sharing options...
