2012 Raga Engine Mounts Out Of Line
jandyb
Finally working on the cracked engine case from early this summer. Bought a new alu cases and have moved everything over exept for some new bearings.
When putting the engine back into the frame this is what I get. Rear and front bolt in place, but the middle bolt hole is at least 5 mm out of line. How do I deal with this?
Edited by jandyb
My brother came along to discuss this, and thats what we ended up with.
Must be a fabrication error this, and proably the reason the engine cases broke in the first place. If something has bendt this would have been looking different I think.
Well... must find a good mechanic then.. :(
Jan
Can you get it to line up without the front engine bolt? Are there any cracks/flaking paint round the headstock indicating movement to pull the front mount out of line which would go some way to explain why the bash plate doesn't fit as well Can't see how the lower mount could move back that much but the front down tubes could
Edited by huski
