tonyp Posted September 21, 2014 Report Share Posted September 21, 2014 Today the front brake lever started to feel more and more firm with limited movement, and then eventually the front brake locked up completely. Has anybody got any idea what it could be ? Is there some sort of release valve that may have failed and is not allowing the fluid to flow back out of the calliper ? It's a 2004 Beta Rev3. Quote Link to comment Share on other sites More sharing options...
clay Posted September 21, 2014 Report Share Posted September 21, 2014 Check to make and make sure, you've got some free play at the master cylinder adjuster Quote Link to comment Share on other sites More sharing options...
naichuff Posted September 21, 2014 Report Share Posted September 21, 2014 Is there free play at the lever before it pushes the piston on M/C Have seen similar problem with rust stopping the M/C piston fully returning releasing the brake pressure holding the pads on causing heat in the calliper making more pressure in the system then no go Does no take a lot under the little rubber boot to do this Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 21, 2014 Report Share Posted September 21, 2014 Full strip and clean needed, probably corrosion in slave cylinder seal grooves and on slave pistons. Agree with #3. MC corrosion can also be cause but less likely from symptoms you describe. Quote Link to comment Share on other sites More sharing options...
naichuff Posted September 21, 2014 Report Share Posted September 21, 2014 Yes had that on my own REV3 One piston was solid On the other REV 3 The steel washer under the circlip was rusty just holding the piston far enough not release the pressure It does not take much Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted September 22, 2014 Report Share Posted September 22, 2014 It does sound like the brakes are dragging a bit, thus heating up the pushes the brakes on harder. One thing to look for in addition to those mentioned by others. Check the pads for uneven wear. I had a set of pads wear on a taper from front to back and when they got worn enough, the metal of the pads would wedge in the caliper and not release properly. Quote Link to comment Share on other sites More sharing options...
0007 Posted September 27, 2014 Report Share Posted September 27, 2014 Also make sure you don't have the reservoir too full Quote Link to comment Share on other sites More sharing options...
