bigmark1972 Posted September 21, 2014 Report Share Posted September 21, 2014 My 2013 factory 300 is coming in on Wednesday the manual is with it. I'd like to have the fuel ready to go when I get the bike. Is there a specific oil that Ossa recommends, or can I use the same Maxima K2 that I use in my Sherco? What ratios are you guys running? Tnx. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 21, 2014 Report Share Posted September 21, 2014 100:1 which you will have to stick with unless you can adjust the fuel injection. http://www.ossauk.co.uk/?Technical%26nbsp%3B%26amp%3B_Parts 1 Quote Link to comment Share on other sites More sharing options...
bigmark1972 Posted September 21, 2014 Author Report Share Posted September 21, 2014 Ah good link tnx Quote Link to comment Share on other sites More sharing options...
canada280i Posted September 21, 2014 Report Share Posted September 21, 2014 100.1 here also Quote Link to comment Share on other sites More sharing options...
ric h Posted September 22, 2014 Report Share Posted September 22, 2014 140/1 here.Runs great. Quote Link to comment Share on other sites More sharing options...
africanjon Posted September 22, 2014 Report Share Posted September 22, 2014 120/1 Quote Link to comment Share on other sites More sharing options...
oldf4rt Posted September 22, 2014 Report Share Posted September 22, 2014 (edited) I'm currently running 40cc oil in 5 litres of petrol which is about 125:1 (when your running in go with 100:1 - 50cc in 5litres) I only use the best oil though - Castrol Power 1 - fully synthetic. Here in the UK many use the more widely available oil in a blue and yellow bottle which is vastly inferior. It carbons up and gums up the inside of your engine - well marketed crap ! You're only using half the amount of oil that other 2 strokes use so you can afford the best. Also the main bearings are lubricated from the gearbox oil so you're only lubricating the main bearing (which is directly in line of the incoming fuel/oil mix) and the cylinder bore/piston. Keep on top of the gearbox oil changes. If you're worried - remove the exhaust front pipe - you can then see the piston with a torch and wipe your finger on the piston and see how oily it is with 125:1 - you'll be surprised. Great bike - keep on top of the rear suspension link bushes, they don't last long but they are as cheap as chips so you can afford to replace them regularly. Tip - get them from your local bearing suppliers - SKF part numbers are usually stamped on to the outside. Edited September 22, 2014 by oldf4rt Quote Link to comment Share on other sites More sharing options...
lotus54 Posted September 25, 2014 Report Share Posted September 25, 2014 I run 100:1 Motorex full synth. About 105 hours so far. Quote Link to comment Share on other sites More sharing options...
motochef Posted September 26, 2014 Report Share Posted September 26, 2014 MAxima K2 110:1 Quote Link to comment Share on other sites More sharing options...
