dadof2 Posted September 26, 2014 Report Share Posted September 26, 2014 (edited) TC would not allow the file type for this image to be loaded so I photographed it whilst I had my camera handy. It shows the waveform of a 4 stroke electronic ignition spark. The blue line comes in from the left, where it drops is the start of coil charging, this lasts about 3 mS. Then there is about a 1mS squiggle and step as the coil current is switched to fire it. The voltage the rises suddenly to about 38 kV for about 1 mS then drops again. The very high spike at about 24.56 mS is the voltage "pressure" building up before the spark jumps the plug gap and gives the burn time. This 1 mS at 38 kV is the ignition spark burn. The 4 oscillations after it drops is called coil bounce and indicates the coil is in good order. This type of analysis is quick and easy and a lot better than swapping parts. For example if there were no charging section it probably means a CDI fault, if there is no switching step it could be CDI or trigger coil. This waveform is using a single sensor on the HT lead. This system is a 4 channel system and can give 4 traces at once. Had I put sensors on CI output to coil, Ignition source coil and trigger coil as well as HT I could have found the exact area of the fault with a quick spin of the engine. Edited September 26, 2014 by dadof2 Quote Link to comment Share on other sites More sharing options...
copemech Posted September 28, 2014 Report Share Posted September 28, 2014 So simple a caveman can do it! Try getting some patterns on a few trials bikes, primary side between mag and cdi, cdi to coil and such, then secondary. Problem on some with integrated cdi/coil though. Quite honestly, at least in my end of the auto trade, we have not tought/used a scope for much other than crank/ cam input to the computer for decades now whth coil on plug things and such, a noid light will do, oh well. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 28, 2014 Author Report Share Posted September 28, 2014 A noid light though useful only tells you if there is a burst of electrical activity of some sort. With the 4 channel scope you can measure for example the current and voltage to 2 injectors at the same time, the slightest discrepancy between the to is clearly visible but a noid check would not show this. With the scope I have a coil on plug sensor can be used for COP systems. Same thing with a HT coil, noid will show its OK and the coil may perform properly when engine is revved in garage. Put a scope on and its a fair bet you will see the defect that only intermittently manifests itself under sustained load. Integrated HT coil / CDI does not make much difference, I would just put sensors on coil secondary, stator source coil and stator signal coil. It is very simple to use, the only difficulty is interpreting if there is a fault when you get an unfamiliar abnormality on the waveform. When you read the electrical problems people post on TC it would make diagnosis far easier if manufacturers fitted a scope socket, and a list of what you should see when all is well. The modern PC based oscilloscopes are a long way from the first automotive cathode tube type scopes. Checking CPS, ABS wheel sensors and ignition is probably most common scope use. My kit cost not far short of £2k, but there are compact combined diagnostic code readers and scopes for less than £130 Which can do pretty well all the tests needed on trials bikes. When I get time I will see about posting some waveforms off trials bikes. Quote Link to comment Share on other sites More sharing options...
