andrewmorpeth Posted September 29, 2014 Report Share Posted September 29, 2014 Yesterday while riding the bike suddenly died while on road between sections.Had plenty of fuel.I removed tank and looked for loose wire and pulled out spark plug.No spark, so i disconnected kill switch from,cdi and the bike fired up,plugged kill switch back in bike kept running but decided to leave disconnected anyway and taped up.Did one more section then after 5 mins roadwork it died again.Put it on the back of car and took it home where it fired up again.Idled in garage for 5 mins no problems.Where should i look first coil or stator?It seems to be when its getting hot? Quote Link to comment Share on other sites More sharing options...
huski Posted September 29, 2014 Report Share Posted September 29, 2014 Can you borrow a coil from another bike and see if it still does it?Is it new enough to still be under warranty? Quote Link to comment Share on other sites More sharing options...
digger144 Posted September 29, 2014 Report Share Posted September 29, 2014 check fuel tank breather, they have a ball valve in the line that sticks starving the fuel Quote Link to comment Share on other sites More sharing options...
andrewmorpeth Posted September 29, 2014 Author Report Share Posted September 29, 2014 When it stopped the second time it cut out instantly and completely so I pulled pipe off fuel tap and there was plenty of fuel flowing.i can try a new coil tomorrow from a friends bike and we can try his with mine.i was just wondering if it was a common fault?it was registered in May 13 so will be out of warranty? Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 29, 2014 Report Share Posted September 29, 2014 Registered in may 2013 but 2014 model ? Had both years bikes and both came with hidra ignition system neither had this problem. Warranty is six months I think Quote Link to comment Share on other sites More sharing options...
