2013 Evo 250 Kickstart Retaining Bolt.
stpauls
Hello all
The kickstart retaining bolt on my Evo 250 keeps vibrating loose. The kickstart actually fell off at one trial, but luckily someone found it for me. This is the retaining bolt that screws into the end of the kickstart shaft. I have tried Blue Locktite and also a star washer. Any ideas?
Thanks
Edited by stpauls
Definately drill ( dia 2mm ) the bolt and use lockwire . I use Goodridge stainless lockwire ( 0.62mm) . I do this on a few of the 'important' bolts on my sons Evo 80 / my 290 , including the kickstart and caliper bolts , rear brake lever clevis pin , brake pad bolts etc . Loctite 243 elsewhere on other bolts . Hope this helps .
Edited by gwl3
I have come across this problem on Betas before and it has usually been caused by build up of old loctite and oil on the threads and bunging up the hole. The hole in the shaft needs cleaning out with a bottoming (3rd cut tap) and rinsing out with brake or contact cleaner the blowing out with compressed air. Clean the threads on the bolt with brake cleaner and a wire brush. Refit bolt with new loctite and you should have no more problems. Loctite 271 or Tru loc 360 may be better than 240. I use Truloc 360.
  • Like 2
