Raga Ignition
asc
hi, read on this forum that someone had adjusted there raga to a softer ignition curve,is this done by retarding the ignition or is there another way of doing this on this bike,put a flywheel weight on ,now took it off,better when its wet with it on,but would n't mind trying other things.bike is a 04 300 raga .
asc, the 04 Raga has a programmable ignition but you need the software and hardware to change it. There are 4 curves available to choose from. Check with your dealer, he will likely have the kit and can do it for you.
