anotherfive Posted October 13, 2014 Report Share Posted October 13, 2014 Whilst riding some obstacles like a step I get the feeling the bike is flooding then immmidiately feels like starvation and engine pinks. Can it be both within a second or two. I was sure float was set ok and this is only time it does it and its costing me marks. Any help appreciated. Keihin carb by the way Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted October 13, 2014 Report Share Posted October 13, 2014 Cant see that been possible . What is the first symptom is it a bork maybe ? If so it could be lean might just be due a carb clean Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted October 13, 2014 Report Share Posted October 13, 2014 Clean carb as first step is never wrong of coarse. Does it have problems with hills aswel? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted October 13, 2014 Report Share Posted October 13, 2014 (edited) Water in fuel, "balls" of water rolling about in float bowl. Is you bike a gas gas or Beta rev 3? Edited October 13, 2014 by dadof2 Quote Link to comment Share on other sites More sharing options...
copemech Posted October 14, 2014 Report Share Posted October 14, 2014 More likely a lean bog than a flood! Clean the carby! Quote Link to comment Share on other sites More sharing options...
anotherfive Posted October 14, 2014 Author Report Share Posted October 14, 2014 Thanks everyone for replying. Yes it's fine on hills I clean the carb quite regularly A plug chop says its running fine. I do get some fuel out of the overflow pipes sometimes This is what makes me think the float is too high but its set a recommended. Still baffled but could it just be no fuel for a second after a hard manoevre. Don't see others having same issue Quote Link to comment Share on other sites More sharing options...
tltel Posted October 14, 2014 Report Share Posted October 14, 2014 Might be worth checking reeds, if you are sure carb is clean, Those Keihin carbs seem like a p.i.a. (never had one on a modern bike) Maybe time for a decoke. TLTEL Quote Link to comment Share on other sites More sharing options...
copemech Posted October 15, 2014 Report Share Posted October 15, 2014 I looks again, no idear what bike or carb, he has a Beta listed? What drain tubes? These can cause issues! Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted October 15, 2014 Report Share Posted October 15, 2014 Help up out here AnotherFive. What bike and carb do you have? Your profile says "Rev3" and you posted in GasGas. What do you mean by "the feeling the bike is flooding." When do you get fuel out of the overflows? Can you see it when you are riding? Has the bike always done this or is it a new condition? Have you made any changes recently before this problem started? Quote Link to comment Share on other sites More sharing options...
copemech Posted October 16, 2014 Report Share Posted October 16, 2014 Re read the thing and he did mention a Kiehin, so therefore, if you have two hoses installed, one on bottom of bowl(overflow) and other bowl vent on right near slide, remove the vent tube to see if it still happens. Insure this one is removed or as short as possible if you just must have it. Do not powerwash water in there though! Do tell results! Quote Link to comment Share on other sites More sharing options...
nicos Posted November 16, 2014 Report Share Posted November 16, 2014 came across this thread while trying to solve a problem on my 2011 280 raga. when going down a steep hill it doesnt run well down low. whats the right setup for the breather hoses on this carb? why would removing any of the two hoses make any difference? thanks! Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted November 20, 2014 Report Share Posted November 20, 2014 They need to be able to breath (or leak). I always put on one hose from left pipe to right pipe. And then cut the tube halfway for like 1 cm open. Quote Link to comment Share on other sites More sharing options...
