shyted Posted January 17, 2015 Report Share Posted January 17, 2015 (edited) Had a thought on the way home this morning about the clutch.Where's the slave cylinder? answer ,in the clutch cover bathed in red hot oil. Boil brake fluid in the system,what happens Brake fade ! Maybe that's the same process what's going on in the clutch slave.it won't boil it but it will be pretty hot in there for a long period of time. Hence the problem coming when the bikes hot. The clutch just isn't operating ! maybe the fluid is just no good. Edited January 19, 2015 by shyted Quote Link to comment Share on other sites More sharing options...
shyted Posted March 1, 2015 Report Share Posted March 1, 2015 (edited) Not that this is of massive interest but the clutch is fixed on my Mont. It was indeed the fluid . Did six hrs last weekend without a hitch So have the MOTUL GP DOT 4 in the clutch system that has a far higher fade point and it has worked without buying any plates or anything. Anyone got ally plates in theyre bike then? Edited March 1, 2015 by shyted Quote Link to comment Share on other sites More sharing options...
guys Posted March 1, 2015 Report Share Posted March 1, 2015 Jep, a set from Mitani. Makes the clutch a tiny bit smoother. Quote Link to comment Share on other sites More sharing options...
shyted Posted March 2, 2015 Report Share Posted March 2, 2015 (edited) Is that in the older or new bike guys ? My 260 is much better to ride now . Such a small thing has made a big difference . Two week's ago i would have traded it in but after a week Saturday ago i'll be sticking with the Mont and continue getting the weight off so it's easier to use . Still hacked off about the kick start pawl though . Edited March 2, 2015 by shyted Quote Link to comment Share on other sites More sharing options...
guys Posted March 2, 2015 Report Share Posted March 2, 2015 First the Mitani clutch plates were in my 2008 4RT and now I've placed them in my 2015. Saves a bit of weight also. 1 Quote Link to comment Share on other sites More sharing options...
shyted Posted March 3, 2015 Report Share Posted March 3, 2015 Aye and for me guy's that's what i want to do get rid of weight . I have a few questions guys i will PM you . Quote Link to comment Share on other sites More sharing options...
taff_d Posted November 21, 2015 Report Share Posted November 21, 2015 Just fitted a Mitani clutch and started using Elf oil in my 2015 and its a totally different bike to ride no more sharp clutch 2 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 21, 2015 Report Share Posted November 21, 2015 +1 on the ELF oil, I just love my clutch with that oil. I just found out that you can get it in the US again too. Though its the same price as before but only 1/2 the amount. 1 Quote Link to comment Share on other sites More sharing options...
cmxi Posted December 7, 2015 Report Share Posted December 7, 2015 (edited) Update on the setup I'm using: Dimpled steel plate set (available from Apico or Jitsie retailers like BVM Moto or Splat Shop) and the OEM friction plates -- 2 each 22201-KY2-000 cork and 4 each 22201-NN4-B00 new type paper -- with Valvoline Dexron VI full synthetic ATF. and#160; I first installed the above in my 2005 4RT in May, and it worked so well I changed my 2014 4RT260 to this setup when I ran out of ELF HTX-740 later in May. I was mainly driven by the fact that HTX-740 had become unavailable in North America and only thicker oils were available. But the above dimpled-steel setup worked better for me all-around -- smoother and longer engagement, no drag, no stick after sitting a few weeks or more, easier shifting, easy to find neutral, much less expensive for oil changes, and oil that's readily available from local auto parts stores. and#160; To give an example of the elimination of drag and stick, as a test I recently started my 2005 4RT after having it sit unused for a month, cold and in first gear, on the 2nd kick. It didn't walk away with clutch stick or drag, just sat there idling. After a little time, with the bike still stationary, I shifted it into neutral with ease. Did this to my bike. Just replaced the paper frictionplates and Apico clutch plates. The prevous owner had already installed the dimpeled plates, but it wass still dragging with the old style paper frictionplates. The upgrade to the new style made a big difference, no more dragging even when cold!! And it is easy to get into neutral at any time. Running ATF Dexron III on transmission side. Edited December 7, 2015 by cmxi Quote Link to comment Share on other sites More sharing options...
geeman Posted December 10, 2015 Report Share Posted December 10, 2015 Jonnyc21 can you please tell me where you can purchase the ELF oil in the USA now !! thanks GBee Quote Link to comment Share on other sites More sharing options...
skippy Posted December 24, 2015 Report Share Posted December 24, 2015 Hi guys I have a 2016 4RT and live in Canada, I found Belray gear saver 75w to work well Quote Link to comment Share on other sites More sharing options...
