social climber Posted August 18, 2005 Report Share Posted August 18, 2005 (edited) Hello guys (and gals..) I have recently bought a 1986 KDX200 to tidy up as a bit of a run around I can take into the woods near tthe house I'm moving to. The bike is already registered but my question is, What are the lighting requirements for a full MOT. I have read through the forums and know it would be easy to get a daytime only MOT, but I reckon it shouldn't be that hard to get the full monty depending on the answers to these questionsr, - Does the headlight need to have a full AND dipped beam if it did not come as standard? If I need the dip, any suggestions for an aftermarket item that runs on 6v electrics? - If I go for a full MOT do I need indicators if the bike did not have them as standard? - Does the brake light need to operate on both brake levers? Thanks for the help... Edited August 18, 2005 by Social Climber Quote Link to comment Share on other sites More sharing options...
bigfoot Posted August 18, 2005 Report Share Posted August 18, 2005 You don't need a dip and full beam only working light. It can be a candle for that matter as long as it doesn't blow out when riding. Indicators are not needed but if fitted must work. Both levers must work the brake light if one is fitted but its not needed at all. Quote Link to comment Share on other sites More sharing options...
g4321 Posted August 18, 2005 Report Share Posted August 18, 2005 Have a look at the following link - one of a number of sites with the full MOT regs for bikes. lot opf things depend on age of bike. Worth reading. http://www.ukmot.com/bike/menu.asp Quote Link to comment Share on other sites More sharing options...
motopat Posted August 19, 2005 Report Share Posted August 19, 2005 bigfoot said: You don't need a dip and full beam only working light. It can be a candle for that matter as long as it doesn't blow out when riding. headlight must conform to some regulations re light pattern emmited - I had an XR600 and bought two lots of Acerbis headlight units (they looked better that standard and bike was supermoto modded) and neither passed an MOT. I ended up taking a daytime only MOT You're right though, on a KDX you shouldn't require indicators (I think it has something to do with no pillion pegs or 'intended use' or not fitted as standard). hth Quote Link to comment Share on other sites More sharing options...
