Rev3 Carb.
stuessenhigh
  • Replies 34
Mmmmm....now this is getting interesting...thanks for some great info Mike and Carl....it certainly sounds like the Dellorto would be interesting since the bits are all on the correct side.
I wonder if Keihin DO make one with the adjustments on the right????..anyone know?
keep the ideas coming in guys and girls :D
VHST 26BD R9354 basic jetting for Beta 250/270
main jet: 120
idle jet: S37
needle jet: 272H
needle: D47
throttle cut away: 50
choke jet: 60 ( I feel that this may be a little bit lean)
needle in 4th position from top
idle mixture screw: 2-3 turns. Please note that this screw has reverse operation from the mikuni.
It
Lets just try to stick to the alternative carb chat on this post guys!!...there have been so many posts over the years regarding the "other" topic/issue.
THat Dellorto is sounding more and more interesting Carl..........I see the one in the picture is an R9359, and you give your jetting info for an R9354.........is there any difference?
mmmm...cheers Howard..and there was me thinking there weren't any alternatives for the Beta.
Sounds like the Dellorto and the PWK would be worth a try..(when i've got some spare dosh!)..think I'll give the Keihin a miss though, with all the adjustments being on the wrong side. :D
R9354 is the number if you buy a std carb from a Dellorto dealer. I guess that R9359 is a specific Beta jetting for Beta Motors which should be very similar to mine.
Carl
