fanticmatze Posted November 2, 2014 Report Share Posted November 2, 2014 While it's getting darker out there and the Trials season winds down, I'm sitting in the Garage and wonder if I'm the only victim of more and more LEDs failing in the headlamp? I ride a 2012 250 Pro. Unfortunately it seems the insert (circuit board) is not available as a spare part, but can only be replaced by a complete new headlamp . Thinking abut good old times (when I could replace a light bulb for next to nothing) won't help. Has onyone found a solution to keep the lamp? I'm thinking about trying to figure out which LED type to solder onto the existing circuit board etc... Keep your feet on the pegs - Martina Quote Link to comment Share on other sites More sharing options...
dadof2 Posted November 2, 2014 Report Share Posted November 2, 2014 http://www.maplin.co.uk/p/5mm-white-led-n28fn See above. The purpose of the PCB (in addition to providing LED mounts) is to control the voltage for the LEDs. If you can check the supply voltage / power to the PCB it may be that you can replace it with a zenner diode and a traditional bulb holder. The zenner diode may not be required if the voltage is already regulated to the 12 to 15 volt range. If none of the above works you could use the fan power supply to power a decent headlight as you fan won't normally run on the road. Quote Link to comment Share on other sites More sharing options...
waynerobshaw Posted September 15, 2015 Report Share Posted September 15, 2015 While it's getting darker out there and the Trials season winds down, I'm sitting in the Garage and wonder if I'm the only victim of more and more LEDs failing in the headlamp? I ride a 2012 250 Pro. Unfortunately it seems the insert (circuit board) is not available as a spare part, but can only be replaced by a complete new headlamp . Thinking abut good old times (when I could replace a light bulb for next to nothing) won't help. and#160; Has onyone found a solution to keep the lamp? I'm thinking about trying to figure out which LED type to solder onto the existing circuit board etc... and#160; Keep your feet on the pegs and#160; - Martina My headlights gone much the same way (only 2 LED lit). Did you manage a repair or a replacement? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted September 15, 2015 Report Share Posted September 15, 2015 How high tech can a led front light be? If its just the leds than replace those and there will be something like a converser from 12V to 5v or something. Quote Link to comment Share on other sites More sharing options...
