rusty ken Posted November 9, 2014 Report Share Posted November 9, 2014 I'm seeking opinion on the best options for a Matchless engine. Is there any benefit in using the older 350 bottom half of the engine? It is smaller, lighter, and the smaller flywheels may suit modern sections better. Has anyone tried this with the later shorter con rod, which should give better torque? Or is there a better option? Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 9, 2014 Report Share Posted November 9, 2014 I use the earlier type 350 motor in my rigid Ajay,still at 350cc with the long rod.I cant comment on the shorter stroke motors,I can only say I'm very happy with the characteristics of mine.But one thing I have found that I was told years ago by the late John Scott, is that its best to use the roadster narrow flywheels rather than the original wide comp ones.His rigid had an old iron motor which he was a great favourite of his. Steve Allen's Matchy which is still very original,(Gerry Holdstock's bike) is flat and very unwilling to rev out like mine will,I think because of its wide comp flywheels.But both bikes will find grip amazingly well, even with a less than new tyre with 8-10psi in it. Brilliant engines to use,very satisfying to creep up muddy banks were often more modern bikes struggle... 2 Quote Link to comment Share on other sites More sharing options...
4stroke Posted November 10, 2014 Report Share Posted November 10, 2014 What about 350 engine with Alfin alloy barrel, Ariel conrod, A65 piston, 75mm bore x 93mm stroke = 410.9cc. Rides very well! 1 Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 10, 2014 Report Share Posted November 10, 2014 What about 350 engine with Alfin alloy barrel, Ariel conrod, A65 piston, 75mm bore x 93mm stroke = 410.9cc. Rides very well! Sounds very nice,mine runs an Alfin barrel too. What do you use for sparks ? Quote Link to comment Share on other sites More sharing options...
4stroke Posted November 10, 2014 Report Share Posted November 10, 2014 Pvl direct on crankshaft, clutch side. Mag and drive removed. Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 10, 2014 Report Share Posted November 10, 2014 Interesting... I tried that on my Ariel,there was so much play in the mains that rotor chewed up the stator ! Do you have any photo's of how you mounted it etc ? Quote Link to comment Share on other sites More sharing options...
aawil Posted November 11, 2014 Report Share Posted November 11, 2014 can i ask why a trick matchless with modern pvl electronics is listed under pre 65, oh i wish i was a scrutineer in pre 65 trials instead of sprint and drag racing, Quote Link to comment Share on other sites More sharing options...
4stroke Posted November 11, 2014 Report Share Posted November 11, 2014 If you are asking a question like that then you would not last long as a scrutineer in pre 65 trials! 2 Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 12, 2014 Report Share Posted November 12, 2014 can i ask why a trick matchless with modern pvl electronics is listed under pre 65, oh i wish i was a scrutineer in pre 65 trials instead of sprint and drag racing, Do you think it's easy to get a good spark at low revs ? Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 12, 2014 Report Share Posted November 12, 2014 Do you think it's easy to get a good spark at low revs ? My holy grail... 1 Quote Link to comment Share on other sites More sharing options...
wallo Posted November 12, 2014 Report Share Posted November 12, 2014 Interspan is the answer to the Holy Grail ....................... Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 12, 2014 Report Share Posted November 12, 2014 Interspan is the answer to the Holy Grail ....................... I know Ken,trouble is I'm stuck in 1950... I WILL make it work. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 12, 2014 Report Share Posted November 12, 2014 (edited) I know Ken,trouble is I'm stuck in 1950... I WILL make it work. Ten to eight ? Edited November 12, 2014 by b40rt Quote Link to comment Share on other sites More sharing options...
jon v8 Posted November 12, 2014 Report Share Posted November 12, 2014 Ten to eight ? No,the year... I think I'm a victim of being born too late,apart from the internet and modern medicine there is little I like about the 21st century. Quote Link to comment Share on other sites More sharing options...
aawil Posted November 12, 2014 Report Share Posted November 12, 2014 i have been using lucas sr1 mags on all of my competition bikes mostly panthers all start 1st kick hot or cold, matchless used them as std before 1965 so problem solved. will. Quote Link to comment Share on other sites More sharing options...
